Phần mềm - Smart SMS v3.16
karlmarx
Chắc hẳn ai cũng thường có những SMS mang tính riêng tư phải không ạ.. Cái này đặc biệt hữu hiệu khi bác nào có những tin nhắn mà không muốn cho ai đọc được. Có thể là người yêu, bà xã hay một người nào đó tò mò chẳng hạn. Vậy thì down nó về dùng đi thôi. Cách sử dụng và chưc năng của nó các bác đọc thêm ở dưới nhé.
Donwload Now
Most comprehensive fakeing solution for protect your private SMS! Stable your family! Peace-Keeping in your family!
Worry about your important and secret SMS being found by someone(your wife/husband...)? SmartSMS could help you! Four type password-Entry could offer a perfect SMS hiding solution for different case!
Our task: Keeping peace for family of the world!!
Operation:
* Three type secret notify:
-Fake notify: NEW!!You can specify a file(video/audio/picture/word/excel...)or any application in setting dialog, then when SMS from mobile NO. in RedList come, SmartSMS will call the associated application to play or open this file/application. For example, you can specify a video file, when your secrete SMS come, windows media player will play it automaticlly. Then just you know you have new SMS, while others near you do not know! you also could set each redlist NO., then you could know who's SMS is come.
-Today plug-in cartoon notify: After installation, go to [Settings]->[Today]->[Items], check "SmartSMS". A plug-in will appear in you today screen, defualt cartoon is "swimming fish", When SMS from mobile NO. in RedList come, plug-in will change into two cartoon people with fake words(you provide in SMS hint), tap the left cartoon girl, plug-in switch to defult cartoon!
-MSN-liked notify: when SMS from RedList No. is incoming, a MSN-liked Notify with the fake words will popup form the right and buttom of screen, then just you know your secret SMS arrived, even someone play with your PPC phone see it, he/she do not know what it mean!
* Four type password-entry:
-Normal password-entry: To show all UI for yourself!
-Backup Password-entry: To show BlackList only. When your mate(wife or husband) find SmartSMS in you PPC phone, he or she must ask for the password to enter it, in this case, you just offer Backup password and tell him or her: it's just tool for block some rubbish SMS!
-Backup password+RedList NO.-entery: To show the SMS list form this RedList NO. only. When you have two or more secret contacts in you RedList and you just be with her/him, she or he ask you show the SMS from her or him to her or him. In this case, You would not like show other No.'s SMS in your RedList. Then you could enter SmartSMS with "Backup password + her/his No."!!
-Urgent password-entry:NEW!! Clear all Redlist NO. automaticly. When someone who know SmartSMS' function find this program on your device, you can enter with urgent Pwd., it would delete all Redlist NO., and then you could explain:"I just use the blackList, no redlist!". Later when you input these redlist NO., you still could see these NO.'s SMS you recived before!
* SMS PPT:
-You could slidingshow your secret SMS in full screen mode. Select a image for every RedList contacts, and SlideShow...It gives you sweet recall!!
* SmartSMS today plug-in:
-After installation, go to [Settings]->[Today]->[Items], check "SmartSMS". A plug-in will appear in you today screen, defualt cartoon is "swimming fish", When SMS from mobile NO. in RedList come, plug-in will change into two cartoon people with fake words(you provide in SMS hint), tap the left cartoon girl, plug-in switch to defult cartoon
* In Settings dialog:
-RedList SMS incoming notify, check it and provide the SMS Hint, you can input the fake words("system error"...).when SMS from RedList No. is incoming, a MSN-liked Notify with the fake words will popup form the right and buttom of screen, then just you know your secret SMS arrived, even someone play with your PPC phone see it, he/she do not know what it mean
-vibration, check it, vibrate
-Fake notify, You can specify a file(video/audio/picture/word/excel...)or any application in setting dialog, then when SMS from mobile NO. in RedList come, SmartSMS will call the associated application to play or open this file/application. For example, you can specify a video file, when your secrete SMS come, windows media player will play it automaticlly. Then just you know you have new SMS, while others near you do not know! you also could set each redlist NO., then you could know who's SMS is come.
-Accept RedList's SMS only, check it, SmartSMS will block all SMS from Mobile NO. , which are out of RedList
-Accept Contacts' SMS only, check it, SmartSMS will block all SMS from Mobile No. , which are not your contacts
* RedList NO.'s Level:
-You can Set protect level of the MobileNO. in RedList: Low level- both system's Text Messages and SmartSMS could recieve the SMS from this NO. High level- just SmartSMS could recieve
* BlackList:
-Add the Mobile TelNO. to BlackList to block SMS from this NO.
Chúc vui, Karl Marx
đùng được anh àh,em vừa cài xong :D,vẫn thấy rắc rối quá >.<
Phần mềm này rất hay, nhưng bác nào upload cái ấy lên 4share đi. Tôi chưa bao giờ vào được RapidShare cả.
Không có cái ấy thì chỉ dùng được vài ngày thôi.
Tải dễ lắm mà anh, chỉ khó với mấy file lớn thôi chứ cái này có mấy chục kb thì dễ ẹt hà, xài IDM 5.09 thì tải dc liền hà, hồi đó xài bản cũ thì nó down về nguyên trang web luôn, bó tay, giờ thì OK rùi
Chú ý: trong qua trình down đừng tắt kết nối đột ngột hay pause là dc, nếu lỡ mất kết nối thì phải remove và down lại từ đầu là dc :D
PM email cho em đi, em gửi cho :)
@ hutboy29: bạn download file mình attach là dùng được mà. Chúc vui
Phiên bản 3.17 luôn đó.
Phần mềm rất hay, bảo vệ hạnh phúc gia đình các đồng chí, Cảm ơn bạn KARLMARX đã sưu tầm, nhân tiện nhắc Anh Em là thêm +84 trước các số ĐT nhé +849xxxxxxxx
