Lakeridgesoftware Wisbar Advance 2.61 Released !
ValkyrieLenneth
Version 2.6.0.1
Enhancements
* Added a "Desktop" option to the cascading start menu. This can be skinned by adding "Desktop Icon=" to the "[Start Menu Skin]" section.
* Lightened up the start menu sublevel image on the WA Default theme.
* Added the Latvian language.
* Added the Galego language.
* Added logging (enabled through the registry) for determing where the lockups occur on some devices.
Bugs Fixed
* Fixed a bug where the Close/OK shortcut could close the WisBar Advance Desktop.
* Fixed a bug where the "Please Wait" skinned object required a full path instead of a relative path.
* Made a small speed adjustment to the cascading start menu.
* Fixed a bug where sublevels in the cascading start menu did not get the appropriate color settings (when not using images for the background).
* The phone signal strength for Flight Mode is now detected properly (on WM5 devices).
* Fixed a bug where the cascading start menu did not scroll correctly after switching between landscape and portrait.
* Made a correction to the battery/memory meter so it will pick up the correct color.
* Fixed a bug where the SIP button would not display properly in Weather Panel's settings dialog.
* Rewrote some of the skinning code in an attempt to speed up the UI.
* Made a change to "play more nicely" with Sprite backup.
Download
Hình như đồ chơi cũ vẫn Work 8-} ....................
Bác làm em tưởng là v2.61, hóa ra vưỡn là v2.601, sắp tròn 2 tháng tuổi rùi :p
đã cài thừ, bản này fix đc cái cột báo sóng cho cái giao diện OSX aQua Mac
cám ơn em iu nhìu, Vừng cũ vẫn tốt :cool:
